Lifter bore sleeves
Results 1 to 6 of 6
Thread: Lifter bore sleeves
    Thank you from BT Gear Head
    Nov 2003
    249
    Lifter bore sleeves
    I seriously think the best idea, for the oil system, is sleeving the lifter bores. Who makes them?
    In America, there is no natural, moral, or legal right, to obligate another person or persons, to your dept or desires.
    Oct 2006
    Tn
    302
    Dunno, but I would search Mopar vendors cause from what I understand lifter bore is same size.....but I am a AMC newbie and on a learning curve on the details of almost everything.....but ask me a Mopar question..........
    48 CJ2a 283
    62 Dodge Panel Truck 3 on tree
    62 Belvedere Max Wedge Stick
    65 Dodge880 383 auto
    64 Jeep DJ3a 2wd
    69 CJ5a V6
    2 CJ6a's V6's 1 T98 4spd
    80 Scout Terra SD33t Nissan Turbo Diesel T19
    83 J20 360 T18
    70 AMX 390 Go Pac 4spd
    70 AMX 390 Go Pac Auto
    Mar 2004
    Conway, AR
    100
    Jesel sells an excellent quality bushing:
    http://www.jeselonline.com/index.php...d37898c7743868
    So does Precision Performance Products:
    http://www.pppcenter.com/06Catpgs/C018.pdf
    I am sure that there are common commercial bushings that can be used. Before this process became commonplace, we used bushings from Sealed Power and Dana that were called king pin bushings. They just happened to be a size we could cut to fit and then ream to size after they were installed.
    Oct 2006
    Tn
    302
    Are the lifter bores the same size as Mopar?
    Oct 2006
    Tn
    302
    Thanks bud.
