No the rods are wider by .020 per rod. We are surface grinding down the rod widths. These are 4340 Chevy 6" rods with honda journals .940 wide. The stock AMC 401/390 crank journal width is 1.849 that means you need rods to be .917 wide so we will be surface grinding .023" off the rods on the crank end instead of making the journal wider on the most of the cranks. One crank is getting wider journals and that will be for a build we do in house
