So when I first got the cover from MC, I found that the dizzy gear ID which was big enough (it had .0015 clearance), didn't fit over the driven gear shaft. In my effort to assemble this engine I just hit the shaft with a right angle grinder and ground the shaft down to fit.
What I was doing was masking a flaw in the manufacturing of the Crown cover.
So I put the cover on a surface plate and took some measurements.
In one plane the hole alignment between the dizzy bore and the pump shaft is off .007 thousanths. Not major but enough to suck. Maybe the cover was distorted by welding. But even when it was pristene the dizzy wouldn't fit.
Jeff
