Found here....
http://cgi.ebay.com/ebaymotors/AMC-3...QQcmdZViewItem
Now this guy asks what the flow numbers are on this $2100 set of iron heads and they tell him this...Pictured is a set of re-manufactured AMC V-8 cylinder heads with 51cc chambers. All our heads are completely checked out for imperfections before machining to assure a perfect product, and can be installed right out of the box with NO further work or cleaning. We stand behind these heads %100. This pair of heads are the rare 319 high compression heads. The heads have been ported and the chambers polished. and contain Manley stainless steel valves, 2.11 on the intake, and 1.71 on the exhaust. We use this configuration because our tests have shown that AMC engines need more intake valve size, since they already have super efficient exhausts. Use these heads to build compression. These heads have milled rocker stud bosses so all types of rockers can be accomodated, and are complete with guide plates and ARP studs. The guide plates are the nice ones from Performanceamstyle, not the cheap stamped ones that must have the flash ground off before use. You must specify 3/8 or 7/16 studs when purchasing. These heads are presently set up for cams in the .6 inch or less lift range, solid or hydraulic. If you would like other springs to match your cam, we will replace the present springs for cost and give credit for the present springs where applicable. IF YOU NEED THE EXTRA BOLT HOLE FEATURE, LET US KNOW, AND WE WILL MACHINE THEM FREE. Figure 52 lbs PER HEAD shipping weight. ANOTHER GREAT PRODUCT FROM KUSTOM KEMPS. See our other products on our page.
OK so there are some variables...but at $2100 some number would be nice.Q: Whats the flow numbers? Jeff
Jan-04-07
A: We don't place much stock in flow numbers, mainly because there are so many variables in the operation of the bench. However, we have a combined 125 years experience between the four of us, so we pretty much know what works and where to do it on AMC heads. We know that 85% of the flow increases are found within 3/4 inch of the valve. That last 15% costs a LOT of money to get, which was not our intention here. Of one thing we are ABSOLUTELY sure, you are getting more head than the money would indicate.
