Solid Roller Lifter Rev Kit
Page 1 of 2 12 LastLast
Results 1 to 10 of 15
Thread: Solid Roller Lifter Rev Kit
    Dec 2006
    =new york=
    69
    rather than running heavier springs I'd prefer to run a Rev Kit -
    in the lifter valley.
    it's old school - but takes the weight of the lifter off the valve
    springs - and that makes sense.
    Feb 2005
    East Bethel Mn
    1,260
    I've never heard of this before, please elaborate!
    VOTEBUTTON
    Dec 2006
    =new york=
    69
    "ULTRA - REV KIT" - solid roller lifter camshafts
    “ULTRA REV KITS” • ROLLER TAPPET (PATENTED) Isky Invention
    Invented by Isky in 1958, the original "ULTRA-REV KIT" has now
    been copied by most other cam grinders.
    A tribute to Isky's
    Engineering Designs.
    The "ULTRA REV-KIT" is engineered to increase engine RPM and
    prolong roller tappet bearing life by pre-loading the roller tappets to
    the cam lobe (eliminating stop-start "Skidding".)
    Pre-load springs are held in place by lightweight aluminum retaining
    bars which install beneath the cylinder head (a drop-in installation).
    Special Note:
    Included with every set of 1241-series Roller Lifters is a package of P/N 200-RTW Roller Tappet Washers, designed to protect your
    Roller Lifters from Rev-Spring “chaffing”.
    They are also available for sale in replacement form as well. P/N 200-RTW...set of sixteen (16)
    pieces.
    ULTRA REV KIT: A device designed by Ed lskenderian .to preload the roller tappet to the camshaft to allow higher rpm. The kit consists of 2 plates which are located on each side of the valley chamber and a spring for each roller tappet. The springs fit between the roller tappet and the valley plate.
    - and -
    Isky doesn't make 'Spring mounting Plates' for AMC -
    but has all the 'other' items necessary:
    http://www.iskycams.com/ART/products/69/revkitL.png
    Go to the Isky site - 'Online Catalog' - it'll open .pdf - go to:
    rev kits pg.23
    CRANE CAMS has all the parts for their previous AMC 'Solid Roller Lifter Rev Kit' - available - except the 'Spring Plates' - .
    Feb 2005
    East Bethel Mn
    1,260
    Thanks!!
    VOTEBUTTON
    Dec 2006
    =new york=
    69
    Quote Originally Posted by BREK
    Thanks!!
    You make a set of plates - better make Two !
    Feb 2005
    East Bethel Mn
    1,260
    If anybody could make a set it would be mc.
    VOTEBUTTON
    REV KIT
    A rev kit for an AMC V-8 would be an excellent new product idea. I will buy the first one !
    As an added benefit I think that the rev kit will keep the lifter from popping out of the bore and uncovering the oil galley in the case of a valvetrain failure.
    Calling MC !
    Bulltear forum member Cook
    Dec 2006
    15
    i have a old crane rev kit for a amc.
    i will check and see what it would cost to mill some.
    i will post what i find out.
    rick wyman
    Dec 2006
    =new york=
    69
    "Boo_Yahh!"
    Dec 2006
    15
    ok, estimate on making billet spring plates patterned from the cast crane ones is 180-200 for a pair, if we can get several sets pre sold.
    thats just the spring plates.
    if we could get several commitments for them that would be nice.
    it will cost quite a bit to make the jig and do the program just to do 1 or 2.
    shoot me e mails if your are serious about these.
    we are currently working on a 2 piece amc valve cover also.
    let me know if anyone hads interest in these as well.
    thanx rick wyman
    americanheavymetal@hotmail.com
