Dana 44's
I have 2 Dana 44's from a CJ but i have no clue what years. One has 3.73's and the other is 4.27's. The 3.73 on is missing cover, drums and all brake parts but internals are good and no slop. To be an everyday driver i'd replace bearings but for just a mudder pour in some oil and go! The 4.27 one is same as above but spider gears have a chip and it looks like some pieces weren't removed quick enough and it knocked the edge of some of the teeth on the ring gear off......its not bad enough to matter, the chips are on the far edge where the pinion has no contact. Im in S.E. Ohio and zip is 43950......hit me up if interested. I have nothing in them so they will go cheap!
- You may not post replies
- You may not edit your posts
Forum Rules
