Results 1 to 5 of 5
Thread: head gasket 304 with 360 heads
    Aug 2006
    ozark mountains
    5
    I am in the middle of a rebuilding a 304 out my cj5. I have lots of questions about the machine work po did. First what head gasket would you put on this motor. There was no head gasket before maybe homemade but not your regular gasket. Next is I can not tell if the block is supposed to have small non casting marks (notches)to clearence the rods at the crank. And last the cylinders have a 1/4 brass ring or some other metal ring at top where your ridge ring carbon would be. Does this sound like the po built up a nice hp engine. I guess the machine shop may be able to tell me more tomorrow as it goes in for minor work. Thanks DD
    Nov 2005
    Middle of the Iron Range MN
    1,229
    have the cylinders been notched to clear the valves of the 360 heads. someone might have had the top of the cylinder machined wider and then put the brass ring in to fill the gap where they didn't need clearance. For head gaskets I would just get a normal AMC head gasket they should all interchange between motors. just make sure the valves won't be shrouded and the chambers line up with the cylinders properly.
    Jun 2006
    942
    Pretty sure the 304 Head Gaskets are different than those for all other AMC engines.
    For 304's the piston holes are smaller, maybe not even round.
    The ones from a '76 304 I tore apart don't apear to be round.
    If using 360 heads, guess you'll need 360 head gaskets
    and as stated the block deck notched for valves clearance.
    Fel-Pro, Detroit, and ROL all offer head gsakets.
    Each one is of a different construction and materials I believe.
    Aug 2006
    ozark mountains
    5
    Thanks to all who replied. Machine shop had bad news. 304 was bored out .060 over and was worn beyond that. So now I am tracking down a 360 block. Wife is mad but who would of known before I started this project.
    Thank you from BT Ultra tech
    Oct 2005
    Longwood, FL
    420
    Quote Originally Posted by cj5.5
    So? Most 304 Blocks can go beyond .060 over. Have them sonic check the walls and see how much ya got left...
    -Dave
    2005 Dodge Neon SRT4 W/Injen SRI, Prothane Race Inserts, Autometer 30/30 Boost Gauge, & AGP Wastegate She's pushin' 19lbs of Boost.
    1976 CJ7/304 W/Edelbrock intake & 600CFM Carb/Q-Track (Part Time Conversion)/TH400/Painless Wiring Harness/HEI Dist.
