Results 1 to 6 of 6
Thread: LUK clutch
    Feb 2005
    Ottumwa, Iowa
    38
    LUK clutch
    What do you guys know about LUK repset clutches???? I have found one cheap, but I know that doesn't always mean "good". I don't want to put another one in 10000 miles down the road.
    Any help would be great,
    thanks
    High5
    Jan 2003
    s.e. minnesota
    1,348
    good quality from what I have herd, if I need one for my j20 that's the way I'd probally go since I don' have money for a centerforce laying around.
    parting several FSJ'S
    Wish I had mine installed you give more info. The shop that rebuilt my tranny recommended Luk. Said they prefer them over the Centerforce.
    Oct 2006
    Eugene, Orygun
    47
    We use them behind the 7.3 POWERSTROKE's in the Ford SuperDuty's, they hold up just fine.
    Oct 2004
    Salem, Oregon
    126
    I put a LUK in my 82 Chero daily driver, 360, T-176, NP208.
    Started out wanting to put in a Centerforce, but it would have needed a different clutch fork set up to use the Centerforce thowout bearing which was diferent from stock.
    Been very happy with the LUK.
    Don
    84 CJ7
    82 Cherokee
    89 GW
    Nov 2005
    Middle of the Iron Range MN
    1,229
    arent the centerforce for racing. I heard that they use counterweights on the pressure plate to increase clutch pressure at high RPM's but at normal speeds the only benefit is better friction material.
