I lack experience with the newer distributors like DUI.
Once I installed a Mallory UniLite conversion,
removed the vacuum advance,
recurved the Mechanical advance,
and phased the stock Delco unit in my '69 AMX
it made a vast improvement.
Probably about 3 tenths worth in the 1/4 mile.
Also run an MSD 6T and Blaster 2 Coil.
BullTear sells new HEI type disributors at a good price, $229 + ship.
It's under Carbs / Fuel Injection in the BullTear e-Store
Be sure to re-use your old dizzy gear if in good shape
and properly set the distrib shaft end play.
If the dizzy gear is no good, should replace both.
Not that easy of a task, hopefully yours are in good shape.
If they're worn they can move the timing around on ya.
As ya probably know the trick with valves is to not get'em too tight.
