Results 1 to 3 of 3
Thread: YJ on a CJ7
    Feb 2005
    Metamora Illinois
    89
    YJ on a CJ7
    I got a YJ body I am putting on a CJ7 frame. I already know about the body mount issue. The questions I have are:
    What did you do with the fuel tank fill? The CJ is passenger side and the YJ is Drivers. I have a good tank and sender with new plate and strap. Can I cut a hole an put it on the passenger side?
    The Dash of a CJ should bolt right on? Right?
    The windshield frame is toast. Should I replace with a YJ or will my old CJ frame work.
    A little too chilly try it right now. We in the midwest have been spoiled for the last 10 years with mild winters. Reminds me of when I was a little one. You had to drink to stay warm.
    Nothing is fool proof to a sufficiently tallented fool!
    I put a TJ filler in the pass side of my CJ body, so anything is possible. If it's a metal tank, a radiator shop may be able to move the filler hole so you don't have to cut/patch the body.
    A CJ dash will fit, but only if you use the CJ heater parts, which may take some additional holes in the firewall. I think you'll also have to use the CJ steering column. You can also use the CJ windshield, but to you have to cut a hole in the cowl to make the defroster work, and use the CJ hinges.
    Feb 2005
    Metamora Illinois
    89
