Results 1 to 2 of 2
Thread: Bearing preload
    Apr 2006
    St.C Ohio, 43950
    433
    Bearing preload
    On a 1980 CJ M20 rear.....whats the bearing preload for the pinion with NEW bearings???? Putting a Detriot in her and figured I would replace the pinion bearings while im at it......the oil was perty nasty! Thanks in advance guys!------------DuNgA!!!!
    Nov 2005
    Middle of the Iron Range MN
    1,229
    I shoot for 25-40 in/lb with new bearings. Make sure you dont go too far with that crush sleeve or you'll have to start over with a new sleeve.
