Ok I'm an Old School guy.. soooo
Page 1 of 2 12 LastLast
Results 1 to 10 of 12
Thread: Ok I'm an Old School guy.. soooo
    Jun 2004
    Central City, Colorado
    1,626
    Someone explain to me how my 2000 wrangler that has no distributor and is all computer controlled can be friggen detonating..??? I thought that was the point of all this computer stuff. I can be motoring along at part throttle and then I realize that I'm hearing this thing pinging away.. dont they have knock sensors and stuff??
    (I mean damn it's a straight 6 not a 12:1 race motor.?? WTF?)
    Dirty Harry.
    I wonder if your crank sensor is bad.
    Feb 2005
    East Bethel Mn
    1,260
    I looked in our cataloging and did not find a knock sensor listed(4.0l). That being said I would have to guess
    1. cam sensor
    2. crank sensor
    3. pcm
    VOTEBUTTON
    Jun 2004
    1,626
    well bad as I hate to admit it I guess I will be letting someone with more knowledge and or test equipment look at it.
    Dirty Harry.
    Be brave my friend!
    Jun 2004
    1,626
    (I quiver in fear at the mere thought of electrons!!)
    Dirty Harry.
    759
    If O2 sensor is gunny bag it can cause a lean run detonation
    what mods have you done to the rig?
    Member #377
    Jun 2004
    1,626
    nothing has been done as far as drivetrain. pretty much bone stock with 98000 miles.. I have a new set of plugs.. but havent changed them.. (much to my surprise there is a rail with coils bolted on the top of the plugs..) I am still working up to this.. what the hell is wrong with good ol plug wires and a distributor??
    Dirty Harry.
    Jan 2004
    388
    No check engine light?
    That thing is new enough that it will throw a light up if the gas cap isn't screwed on tight enough, so the computer should give you some kind of answer.
    Thank you from BT Ultra tech
    Oct 2005
    Longwood, FL
    420
    I am still working up to this.. what the hell is wrong with good ol plug wires and a distributor??[/quote]
    6 Coils that are directly connected to each plug is better than 1 coil connected to 6 plugs. The computer controls the firing of each coil directly..
    its nice in the fact that the computer can really directly control the advance of the engine a lot closer with less moving parts.
    If I could add that to my 360 I'm building I would in a hearbeat. .. then again I like simple.. simple distributor.. simple wires... simple plugs.. those coil packs cost about $110 each.. like $700 to replace coils My friend priced them for her Toyota Corolla...
    -Dave
    2005 Dodge Neon SRT4 W/Injen SRI, Prothane Race Inserts, Autometer 30/30 Boost Gauge, & AGP Wastegate She's pushin' 19lbs of Boost.
    1976 CJ7/304 W/Edelbrock intake & 600CFM Carb/Q-Track (Part Time Conversion)/TH400/Painless Wiring Harness/HEI Dist.
