YEEEEEEEEE - HAAAA !
Found a source for 343-360 CAST 4V FLAT TOP & 2V SMALL DISHED PISTONS !
EGGE Obsolete Engine Parts - 866-534-3443 ( EGGE ) - http://www.egge.com/
Hard to find on webpage cause they're listed under RAMBLER !
also webpage info is incorrect, says 4.000 bore but they are 4.080.
They even also have the original 1.600 compression height rather than 1.580 loke others.
These are made by Egge themself. Said they had'em IN STOCK in +.020, +.030, +.040, +.060
$330 +ship for #L2335 2V small dished Cast Pistons
$306 +ship for #L2336 4V FLAT TOP with (4) Eyebrow valve reliefs Cast Pistons
So all y'all lookin' for some good Cast pistons for your AMC 360's
that'll give ya some good COMPRESSION well here they are !
Wish I'd found these sooner, my 343 motor is allready together, dang gone it !
In a stock '72 and up AMC 360 that was 8.5:1 CR with 58cc heads the flat tops
will give about 11.0:1 CR ! by my calculations, using 2cc eyebrow volume.
Which means the chambers can be opened up to unshroud the valves !
And the 1.600 stock Compression Height gives a decent .012 Deck Clear / Quench.
Have calcultaed the 2V pistons would have about an 8cc Dish volume.
These would give about a 10.3:1 CR ! in a 360 with 58cc heads !
The guy at EGGE, Jim, was not able to give me the dish volume for the 2V pistons.
Working backwards from a 343 2V 9.5 CR I came up with the 8cc 2V dish volume.
If anyone calls'em/ maybe ask if they have the dish dimensions for the 2V and post it here.
Man, finally higher CR cast pistons for 360's ! Whooo Hoooo !
=D> =D>
