Results 1 to 3 of 3
Thread: How many times can a flywheel be ground?
    Aug 2005
    Benzie County, MI
    49
    Anybody have a recommendation for minimum flywheel thickness?
    I have a flywheel from an AMC V8 (likely a 304) that has been balanced for my 401. Over many years of abuse it has been resurfaced at least 3 times.
    Feb 2005
    East Bethel Mn
    1,260
    Not sure on minimal thickness, but if your clutch is not slipping I don't see a problem reusing it. Have it resurfaced again and if your clutch slips buy a new flywheel and have it match balanced to your old one.
    VOTEBUTTON
    Jan 2006
    hickory, nc
    242
    maybe the main problem would be running out of adjustment on the linkage, but then a shim could be bought or made. heat build up may be a problem. thinner metal would heat up fast than thicker. probably only talking like .030" total removed so shouldn't be an issue. a min. spec has to be out there somewhere. let's see what we can fine.
    mike
    bullets don't hurt, but the holes do.
    VOTE BUTTON
