Results 1 to 9 of 9
Thread: fuel pump eccentric ?
Hybrid View
    Dec 2006
    ALLENTOWN PA.
    64
    hello,
    imputting my cam in my knew motor and im wondering about this fuel pump ecc. im running a electric fuel pump. do i needs this im gettint the gears from here help please.
    Oct 2006
    Virginia
    771
    You need it for cam & distributor gear alignment... You could have a spacer made but it's honestly not worth the time/money... I have an electric pump on my 360 and the eccentric is just along for the ride.... Make sure you have at-least one more electric pump on-hand. Also, you should have a return line that routes back to the tank.. this way the line doesn't build too much pressure making the pump work hard and getting too hot... These pumps are made to constantly push/pull fluid through them... once the line is pressurized the only movement of fuel is what goes through the carb and into the engine... which isn't ideal for an electric pump... you'll ultimately shorten the life of the pump. Hopefully this helps a little...
    Dec 2006
    ALLENTOWN PA.
    64
    thank you fifesjeep,
    do you know where to get one? when i got this motor all it was was the block and heads.
    Sep 2006
    Stamford, CT.
    125
    Try Jeep, do you need a cam bolt too? Maybe some one has extra parts they would part with? Sorry I don’t have any extras.
    Dave ----
    75 GremlinX v8 64k
    76 GremlinX i6 (15yr sons)
    70 Javelin MD 390/4sp (360 now)
    70 Javelin 1/4 Drag car 360/auto best time 12.88...best speed 103.64 mph...best 60' 1.835 no tuning
    Dec 2006
    ALLENTOWN PA.
    64
    yes please any extra bolts would br great or just measurements would help timing cover crank shaft
    Cam bolt, the special washer, and eccentric are available new from:
    www.kennedyamerican.com or
    www.americanpartsdepot.com
    And others
    Oct 2006
    Virginia
    771
    If you have access to a junk yard find yourself a wagoneer etc with a 360 etc... you can use those and you'll be fine.
    Mar 2005
    MN
    307
    I have a spare fuel pump eccentric if you need one...just pay me a few bucks plus shipping...may even have a cam bolt too.
    Dec 2006
    ALLENTOWN PA.
    64
    just want to say thanks to those of you that read & replied. im all squared away thanks
