Results 1 to 5 of 5
Thread: Radiator protection
    Nov 2005
    Middle of the Iron Range MN
    1,229
    Radiator protection
    Has anybody put any kind of protection on the inside of their radiators to keep their fan from eating it. Just had my fan get pulled into my radiator while muddin and was thinking of putting some expanded metal over the new one to keep it from happening again. Think this would cause any problems?
    Dec 2006
    Winnipeg, Manitoba
    84
    fan
    As long as it clears you should be fine. I put expanded metal just behind the grill in front of the fan and it hasnt caused any overheating problems. Did your fan hit the rad because of deep water or because it was to close to the rad and the jeep flexed?
    Nov 2005
    1,229
    Deep water and I was using a flex fan put on by a past owner
    Dec 2006
    Winnipeg, Manitoba
    84
    fan
    Fans turn into propellors under water, maybe switch to an old style solid fan or an electric fan, that way you could shut it off in deep water.
    Nov 2005
    1,229
    Im planning on the Taurus fan swap but am having some trouble finding a 75 amp relay to run it with. They supposedly draw 35 continuous and up to 100 on startup. Anyone running this setup who can tell me what to use and where to get it?
