Page 3 of 3 FirstFirst 123
Results 21 to 26 of 26
Thread: head gaskets
  1. #21
    Oct 2006
    Virginia
    771
    GO to COMPCAMS website and they have a detailed instruction on the "How to".... (You can print it off). This might vary a little bit between manufacturers but the only thing that basically changes is the amount of turn(s)... I have Harland Sharp 1.7:1 Roller Rockers on my 360 and it sounds like a Singer Sewing Maching at idle....
  2. #22
    Sep 2006
    kauai HI
    103
    Quote Originally Posted by fifesjeep
    i also have harland sharp, but since the intake is on i can't lift up on the pushrods. i know when the intake starts to go up you adjust the exsaust and vise versa, any pointers. thanks mikey
    doing a frame off, 401/727t/f art carr manule valve body,fiberglass body,4.5 R.E lift, 456 gears locked f/r, 35" crawlers. UPS is helping build it
  3. #23
    Oct 2006
    Virginia
    771
    By removing the valve covers.
    Basic and simple... and watch the rockers as you turn the motor.
  4. #24
    Sep 2006
    kauai HI
    103
    thats funny take the valve covers off. i adjusted them before put intake on, to harland sharp specs. maybe i should of said, if i had to adjust them after i fired her up. the specs, where lift up and down on the pushrod with one hand and take out the up and down movement by tighenting the nut. once the movement is gone, turn the nut one more 1/2 turn then lock the allen nut. just wondering if thats it, if someone has installed harland sharp rockers. thanks mikey
  5. #25
    Oct 2006
    Virginia
    771
    That's basically it.... If some are louder than others you can turn it a little more... Do small turns.... better safe than sorry. My buddy does his while the engine is running.... MESSY!!! But it does the Job...
  6. #26
    Nov 2004
    Homeless, must travel.
    362
    There are neet little tools that you can buy that stop this problem. Well most of it at least. They are little metal clips with plastic in the middle and you clip these to the rockers and they keep the oil from spraying. It still comes out but it doesn't spurt everywhere.
    Pics of Jeeps
