Dana 20 output
Page 1 of 2 12 LastLast
Results 1 to 10 of 15
Thread: Dana 20 output
    Apr 2006
    St.C Ohio, 43950
    433
    Dana 20 output
    So how about im on my way home from my buddies tonite and I decided to get the ol' Jeepers to walk sideways. So i double clutch it and WHAM! Snapped the rear output off flush with the rear housing and also grenaded my Tom Woods CV rear shaft thats only been on my jeep for a lil over a month Needless to say ill have it fixed by tomorrow with a few spare parts i have laying around but i was wondering if anyone here has spent the 471 bucks on a heavy duty output shaft from Advanced Adapters? and if so wether you think it was worth it or not?
    Bulltear forum member Swabie
    Mar 2007
    28
    Take a look on the pirate forum, theres an installation guide and so at least one user who runs it
    I did the same thing here. I went to a Scout Dana 300.
    Pics: http://www.bulltear.com/forums/viewtopic.php?t=6765
    Mar 2007
    28
    Im still wondering these things:
    1. how strong is the front shaft on the Dana20 (in general and compared to a 300)
    2. How big can (should) you go with the driveline u-joints if you run a beefed up dana20 and dana 44 (fr & rear) or 60 axles (rear)? imho the weakest links should be still the driveline u-joints. I also prefer to break them before i break a transfer case or axle shaft
    P.S. if somebody counts, no im not using 3 axles in one truck, its for two different trucks
    P.P.S. @76-cj7: sorry for hijacking your thread
    Apr 2006
    St.C Ohio, 43950
    433
    Tomcat....its alright man. I was actually pondering around with the same questions.
    Mar 2007
    28
    Look at the tech story for the Atlas installation at the pirate forum. There you see exploded D20 cases and broken gears. I think the D20 with the AA shaft is strong enough till you are willing to pay 2.x k for for the Atlas.
    Jun 2004
    Central City, Colorado
    1,626
    shock loads bad...make big boom boom!
    Dirty Harry.
    Apr 2006
    St.C Ohio, 43950
    433
    Hey guys.....guess what I did again last night?!?! Snapped it again except I had my front bumper against a tree screwing around in granny gear then wound it out to 6k in granny then grabbed first and snap! SO I picked up another t-case for 20 bucks and already have it installed and tomorrow my Advacned Adapters heavy duty output shaft will be here =D>
    Oct 2006
    Virginia
    771
    Wow... sounds like fun.... I didn't feel like spending the money for the HD output shaft so I made my own Shaft (Bigger than AA and I made the Housing out of SS)..
    The only thing that you have to worry about now is splitting the case in-half... no joke!.. The weakest part on my Jeep is the driveshaft... it's easier to replace/make a driveshaft and it's a LOT cheaper... Junk yard specials...cut, machine, and weld... keep run-out to a minimum and you'll be straight then if you wanted you could have it balanced......
    Apr 2006
    St.C Ohio, 43950
    433
    Yea the nice thing about what you did was its stronger now but i have no way in hell to make one on my own unless you would have made one for me...... haha
