shifter lingage/dana 20
Results 1 to 7 of 7
Thread: shifter lingage/dana 20
    Sep 2006
    kauai HI
    103
    does anyone have the lingage, that is'nt all sloppy. thanks mikey
    doing a frame off, 401/727t/f art carr manule valve body,fiberglass body,4.5 R.E lift, 456 gears locked f/r, 35" crawlers. UPS is helping build it
    Nov 2005
    Middle of the Iron Range MN
    1,229
    I don't think there ever was such a thing They had a tendancy to wear quickly which isnt necessarily bad. If it is sufficiently sloppy you get the bonus of being able to use 2WD low with the hubs locked in.
    Sep 2006
    kauai HI
    103
    never mind i installed a twin stick .thanks anyways
    Did the twin stick on my Dana 300 and never looked back. Good choice.
    Nov 2005
    1,229
    where'd you get the twin stick?
    Sep 2006
    kauai HI
    103
    i got it from don, at dons repair shop. i got the dana 20 optional kit, you just replace the shift rail for the rear. he's been making them for years, i got the very first one of this kind, it's the revised one, not that the other one's where bad. in the dirrection it says to take out the intermiteate gear, but as i was on my back looking in the case i could see that i could access the set screw in the fork, with a long 3/16 allen (t-handle. once you get the new rail in you might have to move the shift rail back to get the set screw back in. i did'nt know i could move the shift rail back, so i gave up and took out the intermitate gear, still piece of cake. under two hours, on my back. he's seems like a realy nice guy, all stainless, it's sweet. here's he's number. 1-704-279-4697. tell him mikey in hawaii refered you
