1 peice oil pan gasket
Page 1 of 2 12 LastLast
Results 1 to 10 of 12
Thread: 1 peice oil pan gasket
    How about a 1 peice rubber oil pan gasket like the ones made for the 4.0L, for the AMC V8.
    The 4 peice one just doesn't cut it when doing the oil pan with the engine in the vehicle (can you tell what I just finished fighting with)!
    We actually looked into a nitrile piece but they wanted a 50K start up and stock fee. Rubber shouldnt be that hard to make. I will check on this as we progress here
    Jan 2006
    hickory, nc
    242
    nitrile would be cool but man what a startup cost . waiting on the rubber info.
    oh and mycj7, gorilla snot, yellow damnit, 3m weatherstrip adhesive, whatever you want to call it will be your best friend in this job. use a little to tack the pieces up on the block.
    mike
    bullets don't hurt, but the holes do.
    VOTE BUTTON
    Yeah, was a pain in the a$$.
    When I did my 360 it was nice and easy, of course it was upside down on an engine stand. This one was still in the 90 Grand Waggoneer (couch on wheels ;)).
    I have searched online and haven't found anything. But if I did, I know I'd buy some for myself, and I know others that would as well.
    That is crazy expensive!
    Figure there has to be enough of us AMc V8'ers out there to make some demand for it. ;)
    Nov 2005
    Middle of the Iron Range MN
    1,229
    When I did mine half the problem was getting the pan to go past the motor mounts!!
    I had to notch the motor mounts on my CJ to get the pan on (while still in the vehicle).
    No issues like that on a FSJ though.
    Aug 2006
    Pittsburgh
    134
    Quote Originally Posted by mycj7
    just did mine, and i had to notch just the passenger side.
    but yea a one piece like whats avail for the 258's would be sooo much easier
    Apr 2006
    St.C Ohio, 43950
    433
    Just did mine tonite in my CJ.....gots a Milodon 8 qt. pan and had no issues to speak of.....all i can say is to make sure gasket surface is clean and permatex the gasket ends up on the rear main cap and timing cover and let em tack up so it holds.....then permatex the sides to the pan and then install the pan......easy as 1, 2, 3, why would you have to notch the motor mounts???? mine is perfectly fine
    Mar 2004
    Fort Wayne, Indiana
    99
    I glued mine on with careful bead of black ATV.
    I could not get a gasket locally and did not wanna wait for mailorder.
    My 360 was also upside down on an engine stand.
    I know about the dangers of getting a little ATV squeezed out on the inside and causing issues, so I was very careful and I want to think I okay.
    Bryan Smith
    Fort Wayne, Indiana
    - 5.7 HEMI powered
    1982 Jeep J10
    1981 Jeep J20
    Dec 2007
    concord nc
    43
    oilpan gasket
    Just did mine on the old 76 j10 and had little trouble. Put little dabs of silicone on pan then gasket, let dry and she was set. Had to lift truck to get starter off because springs are worn but other that that no problem.
