Oil Pan
Results 1 to 8 of 8
Thread: Oil Pan
    Aug 2006
    Dearborn Heights, Michigan
    155
    Oil Pan
    Ive changed my oil pan gasket 3 times, it appears its leaking out the rear main seal, It also appears like the bolts where over tightened, they arent exactly flush with the surface. Is there any easy way to fix it, is the bulltear custom oil pan worth the extra cost, I had to cut my motor mount slightly to take the oil pan out is the bulltear oil pan any bigger around the bolting area? Thanks!
    Every time I do an engine, I make sure the oil pan and valve cover gasket surfaces are flat. You can just use 2 hammers, one with a head small enough to fit inside the flange, and tap the area around the bolt holes flat. I use solid flat steel stock on the edge of the workbench. The leaks it prevents is definitely worth the time spent.
    Jun 2006
    '69 AMX 12.60@107 - Ohio, unfortunately (:-P)
    942
    Was the block's crank main bearings align honed ?
    Have read Align Honing can cause rear main seal leakage.
    Aug 2006
    155
    I can get a replacement Oil Pan from Murrays which is a Trans-Dapt Oil Pan; Oem, I really was glad it wasnt the crown one. I let you know how this one turns out
    Trans-dapt - crown same mfg IIRC
    I was thinking the same thing. One manufacturer, sold under several different labels.
    What did Murray's get for a pan? You could have purchased one here at Bulltear's E-store. http://www.bulltear.com/catalog/inde...sort=2a&page=3
    (shameless plug)
    Aug 2006
    155
    It will end up coming to about $75 cause I have a 15% coupon, havent bought one yet though
    Aug 2006
    155
    whats difference between the yellow zinc oil pan compared to the stock
