401 wont crank - Page 3
Page 3 of 4 FirstFirst 1234 LastLast
Results 21 to 30 of 40
Thread: 401 wont crank
  1. #21
    Jun 2006
    942
    If the Oil Pressure Relief Plunger is too tight in the bore and sticks it will cause high oil pressure. Sounds like the relief isn't relieving for some reason. If the plunger is stuck it can be a bear to get out of the bore on the filter adapter.
  2. #22
    AMX ... me? Wasn't a problem getting out. The problem was finding the spring on the other side of the shop.
    My problem was a bad "new" sensor - took it back and got my $$ back when I bought the mech guages
    Note to self ... put a rag over the cap when you unscrew the damned thing next time !!
  3. #23
    Mar 2007
    Hickory, NC
    40
    Quote Originally Posted by AMX69PHATTY
    The oil pressure relief plunger will not move at all, it is stuck
    give me some ideas on how to get this thing out
    I thought about taking a tap or a long easy out and trying to get it out, but that would be a stretch
    any ideas
  4. #24
    Mar 2007
    Hickory, NC
    40
    alright guys got it unstuck and cleaned it up real good
    the releif valve and the cavity it sits in
    put everything back together and it did not change anything
    I am thinking that the red HD spring might be the problem
    I am also going to change to a mechanical oil pressure gauge
    which will get rid of another thing that it could be
    the sending unit
  5. #25
    I doubt your actually reading 100psi. If it was 100psi your filter would be bloated. Check to see if it had bloated on you. The plunger goes in nipple end first then the spring goes into the plunger and then the nut. Are you sure you installed the plunger correctly?
  6. #26
    Mar 2007
    Hickory, NC
    40
    yeah I installed it correctly both times
    it is dripping oil out of the oil filter, and around the oil pump housing gasket, I havent looked at the filter to see if it is bloated
    when I pulled the plug the spring came out and the plunger didnt, it was stuck
    I got it out cleaned it up, and reinstalled it
    put oil in it and the gauge went right back to 100 psi where the gauge ends
    0-100 psi
  7. #27
    Red springs are rated at 70psi not 100psi
  8. #28
    Jun 2006
    942
    Sounds like the Relief Plunger is stuck again.
    When I measured a new one from a Sealed Power Kit it was
    .0001 to .0003 bigger O.D. than the stock one out of a '76 304.
    Doesn't sound like much, but it don't take much.
    The new one caused me same problem and ballooned a filter.
    MC, would you happen to know the Plunger Dia. Spec & Tolerance ?
  9. #29
    Plungers should not be larger than .561. The hole it goes into is actually a precision bore that should be held pretty close to .5625 or 9/16". We ream the 626 and the 534 oiling plate holes out to .563 when they are being made here in house. I am suspecting you may be bypassing your filter. Whats the scoup on your oil filter adaptor?...is it new or used and what is the date code on it. Pre 1988 means oil filter bypass...1988-1991 means no oil filter bypass. Some 1987's had it either way. Maybe you forgot to put your bypass back in if was dis-assembled.
  10. #30
    Mar 2007
    Hickory, NC
    40
    the 401 came from a 78 Waggy
    the oil pump housing still has some of the AMC factory paint, so it is used
    the oil relief housing points downwards towards the oil pan
    the oil filter angles back towards the frame rail, and the oil sending unit mounts right above the oil filter in the block with an adapter into the block
    looks identical to the setup that came on the 304 that was stock
    it has a little circle on the outside of the housing with 3 numbers in it
    dont know the order, but the numbers are 2,7,4
    it is pushing oil out of the oil pump gasket, and also dripping out of the screw that holds the spring and the plunger in place
    any other ideas?
    what should be my next step?
