Results 1 to 10 of 10
Thread: power brakes/ stalling
    Aug 2006
    Dearborn Heights, Michigan
    155
    Anyone guess why my CJ is stalling when my power brakes are applied, never used to since I installed it like 6 months ago. It just started.
    Aug 2006
    155
    P.S, I think it might be my pcv valve thats for a chevy 350, though I have of course a 360, or something is wrong with my 670 Holley truck avenger like always
    Aug 2006
    155
    Its not the pcv, and its not a vacuum leak i tested everything. I think now that its something with my carb. Anyways holley is already sending me a new 670 because they send there are defects in earlier models or whatever so i hope a new carb fixes it
    Power brakes on the AMC are usually plumbed into the manifold just forward of the carb. I'd leave it there if you haven't. If there's a vacuum port on the carb, just plug or cap it. PCV should run to a port on the base of the carb.
    Pics or diagram? I need to do that with mine (brake upgrade) - - - whenever I get home... sometime this year.
    Aug 2006
    155
    Power brakes was one of the best upgrades Ive done, with a little fabricating I got it to work, I'm going to switch from the carb to the intake for vacuum as soon as I figure out where it goes
    Nov 2005
    Middle of the Iron Range MN
    1,229
    there is a port on the top of the manifold a few inches forward of the carb right in the middle of the manifold. should be easy to see might have a plug in it or have a fitting that is capped.
    Well it looks like I MAY be home the first week of Aug to re-commence the final stages of the build
    'Course, I've heard that before ....
    Aug 2006
    155
    i switched the vacuum line from the carb to the manifold and it works great!
    Cool Beans Rhino!!!
