Guides to use Hydraulic Roller Lifters
Results 1 to 10 of 10
Thread: Guides to use Hydraulic Roller Lifters
    Considering that our beloved AMC's share lifters with our MoPar bretheren, there HAS to be SOME way to utilize the hydraulic roller lifters they have had the benefit of for many years now. Have you looked into the feasability of making guides ( "dogbones" some call them ) that are for AMC lifter bore spacing that fit the Chrysler hydraulic lifters ? Once these would be available, it would be a simple matter to order a cam to use them. God knows I'd buy more than one set ! How about it MC ?
    -D Payne
    Sep 2006
    121
    Crane already sells hyd. roller lifters for an AMC V8.
    Thank you from BT Master Mechanic
    Mar 2005
    MN
    307
    I know you can buy solid lifters for AMC's. I guess Crane cams make a hydraulic roller lifter for the AMC also. Let me know on the price:) I want to go to one someday.
    But that roller will require a anti-walk kit also. Anyone make cam "buttons" for the AMC. The Indy oil cover I am using has a machined surface for them and they claim it's thick enough.
    A link...
    http://cranecams.com/?show=browsePar...umber=86532-16
    If this new part can't break....what old part will??
    You are missing my point......
    Quote Originally Posted by dwg86
    Oh, yeah, Crane already has them for "ONLY" $525.95 at Summit Racing which is freaking insane !
    I am talking about a part that would allow the use of INEXPENSIVE Chrysler OEM type hydraulic lifters.
    I realize that to many folks here $525.95 is nothing, but to ME that is a significant chunk of cash compared to the Mopar Performance Parts #5249862 hydraulic roller lifters for a reasonable and sane price of $137.69 per set of 16 !
    Quote Originally Posted by jeep_man_401
    I don't know about a cam button, but I have seen a retainer plate that you bolt to the block behind the cam gear, but I can't recall who it was making/selling them.
    -D Payne
    Jun 2006
    '69 AMX 12.60@107 - Ohio, unfortunately (:-P)
    942
    Believe the Cam Anti-Walk plate is through the people in Florida, MadDog or the other folks, American Performance ?, www.oldcarparts.com , or maybe even Nick Alfano or something like that. The Cam Sprocket needs machine thinner on back to accomodate the anti-walk plate thickness right ?
    Yeah, to get the Crane Hyd Roller Cam & Lifters is ~$1000
    Man the Mopar Hyd Roller Lifters are only ~$170 wow
    I paid ~$120 for plain ol' Anti-Pump-Up Elgin Hydraulic Lifters
    Sep 2006
    121
    You can get a cam button from www.amracing.com. It is a nylon spacer that fits over the cam bolt. I used one on my 401...no problems yet. The plate that bolts on the front comes with a rollmaster timing chain with a bearing that goes against the block. I have seen them on ebay, but they are not cheap.
    Mar 2005
    MN
    307
    I wonder if a person could just order one set of links for the AMC lifters threw Crane. Now you have a pattern...
    Are you sure there is no differance between the Mopar and AMC roller lifter? Other than the link? I know Mopar and AMC lifters share the same part number.
    Funny I was reading the "what do you do" posts...man I think I'm on the lower end of the scale too.
    Can a person get a set of 2 rollers from Mopar? Man. I'm makings some calls today about this.
    I used to work in a machine shop and these links could be mass produced pretty easly with a die. I've repaired many and made a few. Anyone intersted in links next 4th of July?
    What we also need a a set of 1 7/8 and 2" EQUAL length hedders...for under $350.
    Feb 2005
    East Bethel Mn
    1,260
    I just checked and mopar part# p5249862 retails for $119.00
    he who dies with the most toys wins!!!
    69' amx 390 4 speed best et 11.85 @ 116mph
    VOTEBUTTON
    Mar 2006
    south Florida
    21
    part number
    If any one is interested the Crane P/N for the hydraulic roller lifters is: 86532-16. Bring plenty of $$ and wait for delivery.
    Mar 2005
    MN
    307
    Stock Mopar lifters are taller than crane....Meaning stock Mopar blocks have a higher lifter boss so the oil groove doesn't come out of the bock at high lift.
    To bad a guy just can't push in a taller bushing and use chevy rollers. Without reaming and honing to Dia. Then there is the link problem with using a chevy lifter. If only I had a Bridgeport mill in my garage....
    By the time you engineer around all that you could just as well bought Cranes lifter. Come on MC, buy a CNC bar feed lath. I'll help check the parts! LOL
    Seems roller cams are going to stay at $1000 for everything for awhile...
