CJ 4 Speed Transmission ? - Page 2
Page 2 of 2 FirstFirst 12
Results 11 to 20 of 20
Thread: CJ 4 Speed Transmission ?
  1. #11
    Sep 2003
    1,155
    MC-rear housing meaning the tail shaft? If so I think it's aluminum (I would have to double check tonight) cause every D-300 I have seen is cast iron.
    84' CJ8-360-Project M170 Jeep
    86' CJ7-258-Mommas Jeep
  2. #12
    Rollbar the Dana 300 has a aluminum tailshaft and the Dana 20 has a cast steel tailshaft. Paint and dirt can hide the material pretty well.
  3. #13
    Sep 2003
    1,155
    I almost 100% sure it's a D-300. 4L, 2wd, N, 4H on the shifter & it looks exactly like one. I must be loosing my mind after all these years. Pics tonight but Peach just called & said she went wheeling this morning B-4 work .
    P.S. I had that backwards, the D-300 has the alum tail & the D-20 cast. Told U I was loosing it.
  4. #14
    Sep 2003
    1,155
    Quote Originally Posted by rollbar
    I meant the housing is cast, sorry, I didn't explain it right.
  5. #15
    Sep 2003
    1,155
    I'll post some pics tonight as well as some numbers of the tranny. Like I said in my first post, back to first grade of Jeeps
  6. #16
    Sep 2003
    1,155
    Well it seems like I need to go to the funny farm or I was thinking of another tranny. Sorry to put U through this (moderator, delete if U want to) but it seems from getting some of the brown mud off the tranny is aluminum so it must be a T-4. Below are the T-case numbers & tranny numbers. Wow, did I have a memory lapse. I'm embarrassed , oh well
    T-case-C-300-15-2 BW 2405
    309007-4
    5364854
    S/N-384138
    Tranny-RGKF23
    1086
    5359389
  7. #17
    Sep 2003
    1,155
    So I went here & it only shows the 176 4spd for that yr. but it's an aluminum housing.
    http://jeep.off-road.com/jeep/articl....jsp?id=277032
  8. #18
    Dec 2006
    Winnipeg, Manitoba
    84
    T4
    If its a T4 it should have the no 13 -51 cast into it somewhere. Its supposed to be a weak trans and best swapped out.
    84 CJ 7 304, Arb rear, 35 BFG,s with a 2 1/2 spring lift only and to many other mods to list, plus a offroad trailer also on 35 BFG,s
  9. #19
    Sep 2003
    1,155
    IT has some numbers cast in the front where the bell housing bolts to. I seen the number 23 & some others but couldn't make them out. I need younger eyes . I'll see if I can get them.
  10. #20
    Sep 2003
    1,155
    Nope it's a 176, looks like this. Plus I have two.
    http://www.novak-adapt.com/knowledge/t176.htm
    Thanks, I must be loosing my mind but U all helped me find it.
