Warning: preg_replace(): The /e modifier is deprecated, use preg_replace_callback instead in ..../includes/class_bbcode.php on line 2968 6 banger heads
Head changed in 80 IIRC and the way I tell is looking at the valve cover area on the head you should see no tapped holes for the cover. Pre 1980 had a finned side on the passenger side of the valve cover and also had all the holes tapped for valve cover bolts.
