OK As with most builds you end up rotating the rear diff to correct the driveline angle within reason. Even with the latest high angle short CV set-up the rear needs to be rotated.
My question is how far can I rotate it before I start starving the pinion bearings? The cover that I am using has a higher than stock filler location for added fluid to help with this, but there must be an upper limit.
