OK, I got one of those big ole sockets & re-torqued Peaches ('86 CJ7) front hubs cause when I replaced the bearings months ago I didn't have one. So I torqued the inner nut to 50lbs & backed it of a 1/8 turn then installed the outer nut & did the same thing & bent over the washer.
Is this right?
I checked the book & or Moses L's book & did it the way he said but someone told me that the procedure was wrong. I should have hand tightened the inner nut & torqued the outer nut to 50lbs.
Rollbar
