I am going to assemble my oil pump, mid plate and 626 cover. I know that the time honored method of using Vaseline as a pump assembly lube / primer is frowned on here. What should be used? I admit that I have used Vaseline for years without any incident but am opened to suggestions.
Since I am using a remote filter and the 626 cover I was thinking about taking the pump output line and backfilling the pump that way. Immediately there after priming the pump via the distributor access. ???????????????
