CJ-8 frame $750 Frame setup for Coils and long arms
Tub (sold)
1" body lift new $40
This is probably the easiest coil sprung CJ 8 you will ever come across. all welding and frame work done. you could be on the trail with a pretty bad ass rig Waggys rear and coils front
would like to sell frame, and front suspension with narrowed front D44 axle all as one $1500 well worth the money if you see it. 1 set of coil springs, long arms, panhard bar, dana 44 no knuckles but includes resplined inner shafts
Chevy 350 4 bolt main, 78/79 el camino motor (so i was told), ran good into the garage, still had cross hatch on cylinder walls when i had oil pan off to reseal, inside was quite clean, flywheel, clutch, new alternator, new starter, edelbrock intake, includes radiator hoses $425
T-18 (13-01)/ D20 $550 (sold)
T-18 adapter AA plate kit for a T-18 to chevy bellhousing, includes clutch fork adapter plate and bellhousing $90
chevy center dump Block hugger headers never used $125
MORE bomb proof CJ motor mounts for chevy 350 $125
Tilt steering wheel $195
PSC steering box $200 (sold)
Stock steering box, Oring fittings, good shape includes stock pitman arm with MORE steering box bracket Zinc $150
Steering shaft $30 (sold)
Drivelines $100 (sold)
NV4500/D300 $1500 (sold)
AMC401 $600 (sold)
Vanco PBS dual diaphram and Corvett MC $350
Dana 30 with air locker 4.10's 56" WMS/WMS includes tire rod and drag link $700 (local pickup preffered)
New Wagonner 5 Leaf rear springs $150 pair
Rubicon Express Long Arms and panhard bar $290 or included with frame
Old man Emu coils 2.5" 3.5" $100 a pair
Stock 20 gallon tank w/ skid plate $130 (sold)
Stock 15 Gallon tank $60
Custom SS Dash with Gauges $475 (sold)
Narrowed D44 57" WMS top WMS set of resplined stock inner shafts. 4.88 gears Setup for tj coils and TJ rubicon express long arms in a cj frame. $700 (local pickup preffered)
Narrowed D60 54.5" WMS to WMS Dutchman shafts 35 spline explorer drum brakes with dana power lok and fresh 4.88 gears 1310 U bolt yoke setup for SOA in a CJ $1000 (local pickup preffered)
Edelbrock 600 Electric choke $175 (sold)
Edelbrock 600 Electric choke $130
Edelbrock 750 Electric choke $190 includes jet kit
York AirCompressor and V-8 bracket $125 (sold)
York Air compressor $100
IIRC and the fronts were custom valved for use with a coil spring front end with no trackbar.....remote resivour. probably the best shocks i could have ever asked for considering the coilspring front end handled really well one i installed them. no track bar. fronts were 12" travel edelbrock shocks $230 on front shocks
located Santa Rosa CA
707-484-6900
