Red neck rear end removal...
Results 1 to 6 of 6
Thread: Red neck rear end removal...
    Mar 2005
    MN
    307
    I hate those silly E-brake cables, you can't cut them. But you can remove them with a Jeep!
    So...now we have the NP205 ready...
    The 14bolt rear is out
    The posi is on it's way from Ebay...
    now we need to pull the front end and gears....
    Nov 2005
    Middle of the Iron Range MN
    1,229
    nice! I've seen it done like that at the wrecking yard but they use the loader and flip the truck over first. They also usually just torch everything off first
    Mar 2005
    MN
    307
    Torches are for wimps (Actually all I own is a small propane torch )
    Jun 2004
    Central City, Colorado
    1,626
    Dude I am so glad that I am not the only one..
    Dirty Harry.
    Jan 2004
    388
    I removed someones bumper the same way once. (and part of his frame)
    Nov 2005
    1,229
    Me too!!! it was a susuki samurai and he hit a light post had to get his bumper off of his tire so he could drive. guess i pulled a little too hard for his bumper and most of it tried to chase my truck down the road.
