Heys guys, need you advice. Currently I have a Amc Th400 with the quadratrac. Looking to replace it. I have a NP203 with part time conversion laying around and since it is free would like to use. Is there an adapter to bolt the two together? Should I look for a different Trans case to use? I will be using a GM corporate 14 bolt in rear and differnet axle up front not sure what yet, so front driveshaft location is not a factor as of now. Also, is a cable style shift mechanism available for said T/C or any other I might be able to use? Thanks guys
