ok so my 360 I got from an older 84 waggy.. installed it.. got it running after priming the oil.. got good pressure.. then all of a sudden one day it dropped to 10 PSI.. ok not good.. then I noticed it drop to 4PSI.. I pulled the cover to the oil pump & removed the old pump gears.. the idler gear was in OK shape.. scrapes top & bottom with a few "particle" divets in the surfaces. the other however had divets intot he face of the gear itseelf like the idler had been rubbing at the center of the driven gear and causing some good wear at the edge of the peak.. NOT good.. and upon further inspection I found small groves worn into the timing cover oil pump housing definitly not GOOD!!
So my question is.. should I go with the standard timing cover with HRC gears or should I got with the Nickle plated one with HRC gears for another $125? is it worth it? I know it'll look nice but is it worth the extra money?
I had already ordered a SS midplate from BJ's offroad thinking this would solve my problem.. but it's not going to work now with the housing all scored up. should I install the midplate as well? what about an oil filter relocation kit with an oil cooler? are they worth it?
How can I check that My cam bearings are alright & not toast? is it possible to check that when i pull the timing cover?
I warn you I'm not rich by any means, but I want this done right..
