Underdrive pulley
Page 1 of 2 12 LastLast
Results 1 to 10 of 18
Thread: Underdrive pulley
    Apr 2006
    St.C Ohio, 43950
    433
    Underdrive pulley
    Bought a Underdrive pulley from the E-store and went to install and noticed it doesn't line up correctly with the rest of the pulleys.......seems as if its too "tall" and the groves are about 1/16" to 1/8" off.....can't figure out how to measure it correctly ....anyone else experience this before? and would it be ok if i just use warshers to space out the rest of the pulleys to make them align?
    Hmm thats very strange! I have heard and have witnessed a couple of 1980 360s that had differetn crank pulley lengths but not on any 304s. I would send it back in for inspection!
    Apr 2006
    St.C Ohio, 43950
    433
    MC....can you give me some measurements to check to see if mine is in fact machined wrong? and if so i do believe i have some parts that have yet to be shipped from you and just bill me for another correct pulley and then i'll ship this one if it is wrong back and get a refund???
    1.905 from mounting surface to the first groove. You could also send us your steel pulley as a model.
    Apr 2006
    St.C Ohio, 43950
    433
    Ok.....i'll get mine measured and measure the old one to check it.....my stock pulley on the motor was just a 2 groove but i had a 3 groove layin around so i tossed her on to run dual p/s belt and they both had lined up ok......
    Apr 2006
    St.C Ohio, 43950
    433
    Stocker measures aboot 1 7/8" and the Underdrive measures 1 15/16"
    Apr 2006
    St.C Ohio, 43950
    433
    SO...if the crank pulley comes to be 1.9375" and the stock one comes to 1.875".these are "about" answers......then that means im going to have to use spacers behind the rest of the brackets?
    I wouldnt mess with it. Send in both pullies and we will make a nice accurate pulley for you. You must have a 1972 motor.
    Apr 2006
    St.C Ohio, 43950
    433
    Well.....from what i under stand the heads that came off of it are from a 71' or 72' so im not sure exactly what year it is......but the rest of my bottom crank pulley i have all seem to measure the same size........
    AMC changed the water pump in 1973, going to a taller pump. The pulleys changed that year too, to match the pump. As long as you have a matched set, you're good, but you can't mix the short and tall pieces.
