FlexPlate or Starter Issue
Page 1 of 4 123 ... LastLast
Results 1 to 10 of 39
Thread: FlexPlate or Starter Issue
    Nov 2007
    Central Texas
    67
    Hello Everyone,
    I have a 77 CJ7 that originally had the 304/TH400/Quadratrac combo.
    I've completely rebuilt the jeep from the ground up over the past 4 years, except, I've used a 360 instead of the original 304.
    I'm having a problem with the starter or flexplate however. I was using a Powermaster starter with the 360 to begin with. But, when I was trying to fire up the motor for the first time to break it in, it made a horrific noise, such as the starter was grinding. I went to the local parts store and picked up a remainufactured starter to see if that would alleviate the issue. It still makes a loud noise, but isn't as bad as the powermaster starter was.
    I've been going round and round with the machine shop that built the engine, powermaster and even mean-green to try and figure out what is going on. Everything seems to be pointing to something with the flexplate. The flexplate on the motor is for a 360 but something still isn't right.
    Does anyone have any suggestions, or, is this a known issue when performing this kind of swap?
    Thanks for any info anyone might offer.
    Aubrey
    Nov 2005
    Middle of the Iron Range MN
    1,229
    is the flexplate supposed to have a spacer behind it to put it in the right location. Could the starter not be long enough to engage the ring gear fully and is just grinding. could the starter have the wrong gear on it for the year flex plate your using. I would check these things out to be sure.
    Nov 2007
    Central Texas
    67
    1. Spacer behind flexplate - This one I have no idea. The motor was removed from the jeep and sent out to the machine shop over 18 months ago and I am having a difficult time getting any info from the machine shop. How else could I go about determining whether or not it does need a spacer? Would the spacer go between the crank and the flexplate to push the flexplate out a bit? If so, I believe it would hit the starter housing.
    2. I've tried multiple different starters. The starters will turn the motor over and actually start it, it just makes a terrible grinding noise when it does. I know the pitch on the flexplate is a 12/14 pitch, and the pitch on the stater (this info came from the guys at Mean Green starters) is supposed to be a 10/12 pitch. I haven't found any other flexplates that are supposed to fit the 360.
    Anything else?
    Thanks for the reply.
    Hmm I wonder if they put the flexplate on backwards
    Nov 2007
    Central Texas
    67
    I was kinda wondering that myself. Problem is, I'm not sure which way it went on to begin with.
    Here are some pics of the setup now.
    http://www.meangreenjeep.com/misc/Picture004.jpg
    http://www.meangreenjeep.com/misc/Picture006.jpg
    http://www.meangreenjeep.com/misc/Picture009.jpg
    Here's what the remanufactured starter looked like after about 10 different starts.
    http://www.meangreenjeep.com/misc/Picture011.jpg
    Thanks for the replies and any other support anyone can offer.
    Aubrey
    I have heard of a offshoot company making the wrong OD flexplates for AMC applications. Is that a Pioneer flexplate?
    Nov 2007
    Central Texas
    67
    I believe it is. Part Number FRA120 I believe.
    Fra120 is a flexplate for a AMC 360 with a th400 application...hmmm. Does your std starter work or what was the deal with it?
    Nov 2007
    Central Texas
    67
    I have purchased two starters for the jeep. My first starter (which is what I was hoping to use) was a powermaster. The starter will actually turn the motor over and start it, you can just seem metal grinding off of the pinion of the starter and hear a VERY loud noise when you do turn it over.
    I removed the powermaster and went and purchased a remanufactured starter just to see if that would correct the issue. Although the noise wasn't quite as loud, it was basically doing the same thing.
    I visited with the people with Powermaster, and they told me that they had never seen this issue before. I contacted Mean Green, and sent them pictures of what everything looked like, and took measurements. I spoke with them again this morning, and they are thinking that it has something to do with the flexplate. They asked what the original flexplate looked like, and I had to tell them that I had no idea. It had been over 18 months ago that I removed the engine and brought it to the machine shop (yes, they took their time with it, but it did turn out great). I contacted my guy at the machine shop, and he can't seem to find the original.
    I've gone over as much as I can, as far as pitch, pinion engaugement, multiple starters to rule out a bad starter, etc. etc.....
    I've been posting to various boards to see if anyone has experienced anything like this before, and so far, this has been the most information I've received.
    I guess I'm going to go ahead and go through the process of removing the transfer case and transmission so I can get to the flexplate.
    Bad part is, I just got all this back together after 4 years of work, and put engine,transmission,transfercase, hell, entire driveline together with the body off.
    Oh well, if it wasn't work, everyone would be doing it.
    Any other ideas?
    Thanks for the response.
    Jun 2006
    942
    I'm no expert.
    Could it possibly be a flexplate for later AMC's made to work with the Mistubishi starter Chrysler changed them to vary late in production before they dropped the AMC V8 all together ? The flexplate used with the Mitsu starters are different than the others as I understand it. Don't know the specifics on year of change to Mistu starter.
    Sure someone here has more specific info about the Mitsu starters.
    Guess the starters you have are fitted with 9 tooth gears ?
    First PowerMaster XS starter I got was fitted with the wrong 11 tooth gear,
    where the correct gear is a 9 tooth for the "old" non-Mitsu Flexplates.
    Don't know the tooth count on a Mitsu starter.
