Power Steering Pressure Line
Results 1 to 10 of 10
Thread: Power Steering Pressure Line
    Aug 2006
    Dearborn Heights, Michigan
    155
    My power steering pressure line broke on the metal portion of the hose where it screw in to the pump, it screws off the hose, so anyways I'm in the process of using a brake like to replace it. I know you guys get really technical when answering questions, I need this to last till Wednesday- will it last 4 days like this or does it build up to much pressure. Can this be a permanent solution, if it does leak from all this rigging?
    100%RHINOLINED,AMC360,D300,D60F&R,35"BFG MT, 6"^,Breaks down every chance it gets. My lady calls it the Death Star
    http://www.cardomain.com/ride/2431277
    Re: Power Steering Pressure Line
    Quote Originally Posted by Rhinolined360
    Couple things here -
    First how do you get a little brake line to fit the connection? My sup & rtn PS hoses are like 5/8"???
    Second, I had brake lines made that support 9K PSI so it should handle the 1-1.5K pressure on the pump pressure side, but ...
    Third, if it is the small diameter line - your going to have steering problems just do to the lack of volumn which means your NOT gunna steer worth a crap. And that is a bad thing
    Why not just replace the hose and fittings?
    Aug 2006
    155
    Napa carries a variety of brake line fittings, as described my line broke on the metal connector, my presure hose was custom made when i started the project. A metal elbow screws into the pump, then the other end screws into the pressure rubber line, then from there it screws into an elbow then screws into the saginaw. I used a brake line about 6inch with a 3/8 male course w/ two female ends, cut off one end hooked in the old nut with a new a farrow and connected it with no leaks to the pump end where the old one broke. I know everything i just wrote sounds very hillbilly, if you guys really care ill take picture of what i did, but it worked.
    Aug 2006
    155
    I am replacing the line as described too, lol it wont be in till wednesday!!!!! but my brake line job has gotten my jeep steering around
    Yes it will hold. I have made many hydraulic lines for steering in the past and modified many different power steering lines with flares.
    With brake line? That's only 1/4 ID at best!!! How do you get enough flow thru it??
    I said it will hold..may not work well enough but You can also find larger ID brakeline as well. Most parts auto stores have universal hydraulic fittings and hoses and most will fix or make you a new line.
    Apr 2006
    St.C Ohio, 43950
    433
    Well wut it seems to me that he's prob using 5/16 or 3/8 metal line.....its all labeled brake line from 3/16 up to 3/8 and the 3/8 would be the same size as the metal part of a OE line so it would work out great.....i just dunno bout not having any flex in the line with the rocking of a reving motor.....might stress crack it unless you coil it a few times
    Apr 2006
    St.C Ohio, 43950
    433
    After going back and re-reading the previous post i understand your set-up now.......sounds like it would work just fine and dandy and as long as they don't leak id leave here alone and run it
    Aug 2006
    155
    yeah its 3/8
