The motor and tranny swap are about to begin. I already have the D300 out and cleaned up, ready for a 4:1.
Next up is to yank the TF999. I plan to take it and my new (from a running, driving 258-powered 1984 CJ) TF999 to a transmission shop to have the manual valve body pulled and steam cleaned, then reinstalled into my new TF999. I avoid water like the plague, but I might do the vent relocation trick as well. I'm pulling the TF999 next weekend. I will get the tq converter while I'm under there. Thoughts?
The current motor is a 1972 AMC360 with an Edelbrock intake, cam, and old skewl Edelbrock valve covers that were sandblasted and clearcoated (for maximum bling!). It runs on the www.gotpropane.com kit. I'm replacing it because it burns oil (leaky valves) and the exhaust manifolds are toast (booger welded by a previous owner). I'm swapping the intake, propane, and valve covers over to the new motor.
The replacement motor is a 1986 from a Waggy. It has all the miserable emissions junk all over it. I bought it from a trustyworth friend, and he tells me it ran like a top. The body rusted away, and the axles and engine were pulled.
Now for the questions:
1. I'm thinking of running the infamous Taurus electric fan and using this guide to perform it:
http://www.rebelrockrunners.org/taurus_install.htm
I plan to run it on high. This is strictly a rockcrawler, and it needs all the cooling help it can get. Is this a good swap? From what I can tell, the fan is not an integral part on the front pulley. I think it can be left off with no issues. Correct? Side note: it always ran hot, and I have no fan shroud. I think it would be easier to run the Taurus fan that to build a shroud.
2. The PO of the Jeep ran the 4.2L I-6 radiator with NO provisions for an auto tranny. He had a micro size cooler on it, which probably led to the tranny's demise. Would the radiator from the CJ be a swap that's worthwhile? I hear that it's imperative to get the temp of the tranny fluid up, but not TOO hot. I'm going to run an external cooler as well. What would be an appropriate size? I'm thinking an 18,000GVWR.
3. Should I do anything to the motor prior to dropping it in? This is a budget, so anything not required isn't happening. Timing cover? Oil pump?
4. What's a good way to clean up the motor for some paint? Regular old degreaser? Without angering the AMC gods, I want to paint it red.
5. I'm considering leaving the A/C pump on it and using it for OBA. Is it on its own bracket with its own belt? How would I go about engaging it?
6. If I can scrape together additional cash, what are the serious bang for your buck things or real must haves?
Thanks all.
Gratuitous poser shot:
