Results 1 to 10 of 10
Thread: gas mileage
    Dec 2006
    Winnipeg, Manitoba
    84
    gas mileage
    gas is getting real expensive, I used to have a Toyota Landcruiser with a 3.5 liter 4 cyl diesel, it got 28mpg always. How about an adapter plate of some sort to mate up a diesel to a Jeep transfer case? Which leads me to another one, a good diesel motor around the 2.5 to 4 liter size. Oh yeah, that Toy was unstoppable off road due to the torque.
    Apr 2006
    St.C Ohio, 43950
    433
    Cummins 4bt is 3.9 liter and uses an adapter to a GM pattern. But at around 800? lbs..........its one heavy motor.
    Feb 2005
    East Bethel Mn
    1,260
    What about using a 2.8l out of a 2005 jeep liberty?
    VOTEBUTTON
    Apr 2006
    St.C Ohio, 43950
    433
    the new 2.8 would be a sweet idea but how hard would it be to wire and how much would it cost?
    Nov 2005
    Middle of the Iron Range MN
    1,229
    you could look into an old mercedes diesel and see if anyone could make an adapter for it. or if you really want a small motor look for one of the old rabbit diesels.
    Feb 2005
    East Bethel Mn
    1,260
    Wiring sucks a$$, it probably wouldent be very cost effective? the best way to go about getting a 2.8 would be to buy a salvage liberty.
    VOTEBUTTON
    Dec 2006
    Winnipeg, Manitoba
    84
    gas mileage
    First off an 800 lb motor is way to heavy, and a VW diesel is prob way to small. I was told that the motor in my old cruiser was originally a shipboard generator diesel, don,t know if thats the truth but there must be many different diesels out there. The 304 prob weighs in at say 500 lbs, so something in that weight range would be ok. Doesn,t Isuzu make a couple of diesels for GM? Its just that gas is getting up around $4.50 a gallon here and I have no intention of stopping wheeling my CJ but there must be something, propane has been discussed but the tanks need to be outside the vehicle and I,m not sure if propane is much better than gas, especially where I live, we just had 2 weeks of 40 below with the windchill. An oil burner might not be a bad idea.
    Mar 2004
    Fort Wayne, Indiana
    99
    Quote Originally Posted by 76-cj7
    X2!
    Wiring the computer to work correctly with all those sensors in a foreign vehicle would be a nightmare!
    This why folks typically use mechanically injected engines, like the Cummins 4BT/early 6BT; Nissan SD33T and the GM 6.2/6.5T.
    No stinking computer!
    Bryan Smith
    Fort Wayne, Indiana
    - 5.7 HEMI powered
    1982 Jeep J10
    1981 Jeep J20
    Feb 2007
    DC suburbs
    333
    The cummins 4BT is the best choice out there for oil burners. Find them in oil bread trucks and put a NV4500 behind it.
    Apr 2006
    St.C Ohio, 43950
    433
    Bingo!
