What is the advantage to running the camshaft in the 4 degree advance position? I have a well built 401 that I use for racing only. When I installed my custom solid lift cam I put the timing gears in in the normal straight-up position. Since my motor is built for high rpm power would the 4 degree advance position gain anything? The cam comes in around 3500 rpm, I have a 4,200 stall, 2" upright headers, single plane intake and the heads are ported. Thanks!
