Page 1 of 2 12 LastLast
Results 1 to 10 of 11
Thread: Parts interchange
    Dec 2007
    concord nc
    43
    Parts interchange
    I would like to put a tilt wheel in my 1976 J10. What years Grand Cherokee has a column that will fit?
    May the wind be in your face and the sun at your back.
    1976 J10
    1988 5.0 Mustang
    1995 Ford Taurus
    1995 Sportster 1200
    Re: Parts interchange
    Quote Originally Posted by woodfar51
    A chevy column will work. Stuck one in both the CJ and YJ - both tilt wheels!
    #20 = we aren't going to make #14 by Valentines day (tomorrow)
    I'm disappointed. We were doing good for a couple days
    GO VOTE!!!
    Jun 2004
    Central City, Colorado
    1,626
    any of the mid 80's FSjs should bolt right in.. they didnt change much on the SJ's .. I used an 83 wag donor for mine..
    Dirty Harry.
    Dec 2007
    concord nc
    43
    Parts interchange
    Thanks for the info. Am going on the Pull a Part web site to find what FSJs are on their lot.
    1976 J10
    1988 5.0 Mustang
    1995 Ford Taurus
    1995 Sportster 1200
    Jan 2003
    s.e. minnesota
    1,348
    you'll need to look for 85 and older, 86 the dash changed, that coloumn has the headlamp dimmer and wiper switch in the turn signal switch.
    parting several FSJ'S
    Dec 2007
    concord nc
    43
    Parts interchange
    Seems that anything I might need for my big 10 will need to come from 85 and older. This will make trips to pull a part much easier.
    Thanks for the help.
    PS. Would like to hook up with someone in my area,with same type
    truck, to share info on found local Jeep treasures.
    1976 J10
    1988 5.0 Mustang
    1995 Ford Taurus
    1995 Sportster 1200
    Jan 2009
    weymouth ma
    11
    what about the electrical connections on the column ? i have a 74 waggie and a tilt column from a 82 g-wag is this also a plug and play ?
    Quote Originally Posted by 86cj7
    It is if you cut them off and use waterproof connectors like I did
    Nov 2005
    Middle of the Iron Range MN
    1,229
    anything can be made plug and play if you have the wiring diagrams and know how to solder
    Jan 2009
    weymouth ma
    11
    where would one find a wiring diagram for a 74 and a 82 waggie ?
