Thank you from BT
Grease Monkey
What is the AMC Valve Spacing and Angle?
Does anyone have the dimensions for the AMC V8 valve spacing and angle?
I am looking to swap 305 pistons into my 304 stroker build and am curious if the 305 valve reliefs will work or not (without machining). 305's are 23-degree stock, from what I can tell. A valve relief diagram can be found in the JE TOOL BOX at : http://www.jepistons.com/cat/je/auto..._23_flat.shtml
Thanks all.
Sincerely,
Greg Taylor :) <><
AMC's angle is 18 degrees IIRC.Don't have any idea on spacing
- You may not post replies
- You may not edit your posts
Forum Rules
