Thank you from BT
ULTIMUS MAXIMUS STATUS
Originally Posted by
ironman_gq
Nice place - haven't seen their site before
Maybe it's time we discuss PLACEMENT of the louvers?? On top would allow water directly down on the air cleaner, carb and engine, on the side?? I jsut have the air cannister and the battery (opposite sides). I think either top or side would allow heat out, butthe side would protect the carb a little better.
Thoughts?
Helpfull BT forum member
Junior wrench of the Forum
I thought about that, but not a lot. I've got the typical 14" air filter housing which is raised up a bit and has a drop on the lower half of the housing. It's not likely water is going to get into it from the top, I'm much more likely to have water shoot into it from the Krawlers as I have no inner fender wells now. I should get some, they salt the hell out of the roads here and *everything* gets covered in the crap.
Instead of all thoughs fancy louvers, just make yourself some 1" blocks, install them under the hood hinge on the body.
The blocks I made are 1" square tubing, I cut them 3 1/2" long, found some square black plastic plugs (fence section) at Home Depot to finish them off. They work great and at first glance you don't know they are there.
If you insist on cutting up your hood, find a custom shop and have some real louvers stamped/cut into the hood. Those are real cool!
If I can find some pictures, I'll post them.
http://www.genright.com/category.aspx?categoryID=117
- You may not post replies
- You may not edit your posts
Forum Rules
