Thank you from BT
Tech Master Bulltear Forum
t18 or one of the truck 5 speeds with OD NV4500 or something like that. depends on what your doing and if you need a deep first and OD
Ok new problem now anytime i drive over ten minutes the jeep catches on fire. There seems to be trans fluid running from between the engine and trans. What could be leaking in there? Dont have the time or extra cash right now for the standard transmission swap.
Thank you from BT
torque converter and front seal. chances are good that they have hardened over time and have cracked. drop the tranny and pull the converter to find the problem.
The trans stator has bound up and is causing fluid to back up in the cooling line, which makes it even hotter.
- You may not post replies
- You may not edit your posts
Forum Rules
