alternators - Page 2
Page 2 of 2 FirstFirst 12
Results 11 to 17 of 17
Thread: alternators
  1. #11
    Nov 2005
    Middle of the Iron Range MN
    1,229
    everything but the wiring plug i believe. if you get the one wire version it will be a bolt on.
  2. #12
    Feb 2007
    DC suburbs
    333
    Will I still be able to run the CS-144 with just one belt? I need two for my PS pump.
  3. #13
    Nov 2005
    1,229
    one should do it just fine. I was running a 140amp powermaster alternator on one belt with no problems.
  4. #14
    Jun 2006
    942
    Those are the early Motorola style brackets in your pictures.
    Are the late model alternator brackets better to use with a GM style altermator
    than the early AMC brackets originally made for the Motorola style alternator ?
    I think these are the late model brackets made for the GM style.
    Found on 1976 to 1980 I think, is that the right years ???
  5. #15
    Feb 2007
    DC suburbs
    333
    I have an 86 360 sitting in the garage. Would it be a good idea to swap the brackets from the 86 motor?
  6. #16
    Feb 2007
    DC suburbs
    333
    Sometimes things fall into place...Can't get much simpler than this:
  7. #17
    Thank you from BT Ultra tech
    Oct 2006
    KEARNY, NEW JERSEY
    428
    CS-144
    YES DAN THERE IS AN ADAPTER FROM WRANGLER POWER PRODUCTS THAT MAKES THIS WORK. I ALSO RECOMMEND THE BULLTEAR HIGH ALT MOUNTING SET UP TO KEEP IT OUT IF THE MUCK. THAT'S WHAT I RUN
