Increased Oiling Parts?
Results 1 to 4 of 4
Thread: Increased Oiling Parts?
    Bulltear forum member Swabie
    Oct 2006
    LUBBOCK, TX
    24
    I was looking at the Bulltear parts that increase oiling to the crank. Would it be ok to run all three increased oil parts (push rods, rocker arms, and cam bearings) together? I'm sure it would be but I just want to be sure. How about those three parts along with the intake valley oil line mod together?
    No, not all three your pressure will be too great!
    Oct 2006
    LUBBOCK, TX
    24
    Which one's would you suggest using with the valley oil line mod?
    If you dont have tha valley line in try a set of smaller hole cam bearings. It is possible to modify cam bearings yourself you will need to drill a .201 hole and gently deburr. This will set the pace for better crank oiling for the term of the engine life.
