Results 1 to 5 of 5
Thread: SOHC Heads
    Thank you from BT Ultra tech
    Oct 2005
    Longwood, FL
    420
    SOHC Heads
    MC We need SOHC Heads for AMC Blocks.
    2005 Dodge Neon SRT4 W/Injen SRI, Prothane Race Inserts, Autometer 30/30 Boost Gauge, & AGP Wastegate She's pushin' 19lbs of Boost.
    1976 CJ7/304 W/Edelbrock intake & 600CFM Carb/Q-Track (Part Time Conversion)/TH400/Painless Wiring Harness/HEI Dist.
    Oct 2003
    CT
    1,857
    Re: SOHC Heads
    Quote Originally Posted by dbesade
    you are thinking about your Neon to much.
    - Mahatma Gandhi
    Feb 2006
    pine grove, pa
    36
    I'm building a 77 cj7 w/quadratrac http://quadra-trac-jeep-cj7-buildup.blogspot.com/, what are your thoughts on the painless wiring? I'm getting mixed reviews.
    Feb 2008
    Canada
    77
    The Painless wiring harness? I loved installing the thing. I put one in my 77 CJ a couple years back. Easy as pie, got most of it done in one evening. The old wire was pretty rotten and the kid that had the Jeep before me had done a shitty patchwork job fixing some circuits. Having an entirely clean wiring harness kicks ass. With the exception of the actual motor connections, the entire thing is already terminated which is nice. I liked it so much I picked up the 12 circuit universal harness they sell and put it into my 67 dune buggy, which was another wiring nightmare.
    Oct 2005
    Longwood, FL
    420
    Re: SOHC Heads
    Quote Originally Posted by pyagid
    My Skittle has a DOHC Head thank you. But SOHC Heads on an AMC Motor would reduce the rotating assembly a bit. It could be done I think.
    oh and 20lbs of boost this weekend way too much fun. Sad when my Jeep gets better gas milage than my SRT4 ;)
    -Dave
