Warning: preg_replace(): The /e modifier is deprecated, use preg_replace_callback instead in ..../includes/class_bbcode.php on line 2968 Oil pressure past 45 psi.
Rebuilt this 360 a few years ago. Has the nickel cover, pump, spring, nickel plate. All came from bulltear and all. Anyway, lately I've been noticing pressures going past 45 psi, and fluctuating depending on idle speed. I seems that it was pretty constant before and would instead fluctuate between 20 and 45. Could something plugged cause this? Or the spring that regulates the pressure?
I'm running the permacool oil filter relocator and a parallel bypass filter. I'll change filters this weekend but since I'm under there was wondering what I could look for.
