Whats the best compressor for ARB lockers. also can you use one compressor to operate both lockers?
2007 durango
79 cj7 401 t-18 488 s lockers both ends 35 s
97 F350 crewcab 4x4 power stroke banks equipped. just added the exh. brake. I LUV MY TRUCK
94 WRANGLER
90 WRANGLER BASKET CASE
ARB makes a compressor for thier lockers, and when if piped to a tank can be used to air up tires. Best compressor? Wide open question with 1,000,000's of interpretations depending on whom you ask. Electric or engine driven? Converted A/C pump or after market, engine size, number of batteries, etc, yada, yada, yada.Originally Posted by 81cj
Identify ALL your air needs (lockers, tires, suspention, tools ... ) and get one at least 25% larger :-)
I dont see why you couldnt power em both with one compressor the pressure to them is controlled by your switch not the fact that the compressor is on. Just use a small air tank as a reservoir to make sure you have enough air
this is what ARB does one compressor with a T fitting adn two pressure switches.Originally Posted by ironman_gq
I recommend doing the belt driven compressor just because i hate lots of wires under my hood
Member #377
Wire's ain't nut'nOriginally Posted by Dusty
First: The engine drive will take some HP to turn when engaged, and slightly less when it's not. Think A/C compressor, it spins all the time, but only 'drives' when the magnets are engaged to drive the pully and crank the pistons.
Upside: You can control when it 'engages' or have the press switch do it for you so you always have, "a full tank".
Downside: You gotta be running the engine to fill the tank when your using air tools or filling lotsa big tires, and it can only go in one place.
Elect-trick
Upside: You can run off the battery if your in camp and pumping up mattresses (or sheep) No HP drain on the motor when it is running, and can go wherever you want it!
Downside: Gotta make room for it some where, and yes - wires.
They both have the same plumbing involved to wherever the tank and outlet are.
my bad i wasnt clear i was refering to a york AC compressor since they came on many AMC AC equipt vehicles and are easily adapted
Member #377
Yeah, your bad!! Slap yourself on the wrist and have a beerOriginally Posted by Dusty
Haven't seen you for a while - you OK?
Originally Posted by Mudrat
Work, Work, Work. oh yeah remodel house, build engine for jeep, learn how to tune GM TBI with the moates system and get my jeep running at a decent level.
thanks for asking
Member #377
Well you have a job anyway. Work I can relate to, too. Here it is almost Santa time and I have 200 emails on my account at home some that I haven't gotten to in a month!
funny how that works. Yep nose to grind stone attempting to keep what i've got. no complaints happy to still be bringing something home for the table.Originally Posted by Mudrat
Goodluck hopefully you get to spend a little time with family over christmas and get caught up on those emails
Member #377
