W-AILLLLLL the saga continues ....
Got some time to reassemble the parts, it was a real B1TCH to get the spindle in. After the rubber dead blow, I took the air wrench to the studs and then went to get the rotors turned - 3 shops said no, too pitted. So I ordered new ones (EBay $44 for the pair =D> ). I took today off to finish bead blasting the hub and parts and reassemble - something wasn't right - WAY to muich force to get parts to fit (especially the spindle into the 'C') .
So now I find the outer 'C' is "BENT" Don't know if it was the pressure needed to extract the ball joints, the heat added to make that happen or a combination, but when I seated the brake caliper, spindle, and tried to get the rotor/hub assy on, it didn't fit right. Not to mention there is no room for a grease zerk with the axle in there
Took the hub off and looked at how the spindle and the backing plate was 'seated' and it's not flush with the knuckle Top and bottom there is better than 3/32" between the brake support and the spindle, the sides are tight.
"Ready to run" my ass!!!! These frigg'n axles are costing me time and $$$$ Not looking good for the FSJ Invasion right now - I'll be in FL for a month between now and then
