Finally got around to building my new driveline after my shackle reversal. I used 2 1/2x2 1/2 receiver tube for the outside and 2" tube for the inside. I cut a couple of chunks of the inner tube and then ground down the yoke to center the one yoke for the outer part then welded that in. The other yoke I just shimmed it to center and then welded it to the smaller tube. I was lucky that I didn't have to do much grinding or shimming to get everything centered. I welded a bunch of spots on the inner tube then ground them to get a more snug fit. I hope I won't get much noise from it now. If it gets loose I can always put a few more spot welds on again. I can't wait to try it out!
The pics show the yokes off by 90 degrees, I'll just pull it apart and put it in right.
